rvexodus
Nov 16, 2022Explorer
HELP: Suburban SW12DEL propane issue
Having an issue with my sw12del water heater on propane side. Running the burner everything is fine. Gas is flowing. Good flame in the burn chamber. Then at some point the gas starts fluttering almost as if it’s trying to shut off (not sure if that is what’s happening so don’t read into it). Flame starts to appear near the orifice in the main burner assembly (the tube where the air and gas are mixed). At this point, it makes a fluttering popping sound much like a gas flame that’s exhausting or running out of gas.
Also note worthy is my pressure relief valve started dripping (1 drop every 5-10secs). There’s some hard water deposits around the opening. Now I did flush the system around a month ago with a mild vinegar solution. So this could be unrelated to the flame issue but again worth noting. The dripping does happen even with the heater off. So I’m guessing the valve just needs to be replaced.
There was water forming around the orifice from the dripping. Was thinking maybe the water was interfering with the flow of gas but I wrapped a little foil around the pressure release valve to divert the water away from the orifice but still having the flame issue.
Hoping someone else has had a similar issue and / or can provide some recommendations.
