Have any of you replaced the seal on the 8 cu. ft. Norcold refrigerator? We noticed that our seal has a 3 inch tear in it at the bottom of the door. Any advice or suggestions? Thanks, Don
I had a hinge break. No replacement part. Had to buy a new door. After calling several RV repair facilities I did fid out that many keep old doors for use as replacement parts. You might want to check local repair facilities as you travel, You may find one that has a seal that will fit. Good luck.
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
