yolo6886's avatar
yolo6886
not so fantastic vent
hi everyone! Today I decided to tinker around with my fantastic fan installed in my bedroom. For some reason I was unable to open it the handle was jammed. I removed the black twist handle and then the two screws on either side of it assuming I would see a gear that was stuck. instead it's actually attached to a motor and the twisting handles inoperable. Using a pair of needle nose pliers I was able to figure out that the gear to open the fan is fine. However as soon as I turn power on to the vent the motor forces the event to be returned closed. when I manually open event with a pair of needle nose pliers the main fan will also not turn on. I check the fuse its a four amp just as required and its in good condition. I'm really stumped! Can someone recommend either a good website or give me some helpful information so that I can at least open and run this? Thanks a lot everyone!
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
