B_O__Plenty
Nov 19, 2015Explorer II
riven1950 wrote:I have the same grill and I gave you the exact solution..
OP here.
Don't see how I am going through 2 regulators. Hose is straight from 20lb tank to grill, not tanks on TT.
Can't swap the ends on the hose as donn0128 suggest. Fitting on tank and grill are not same.
Old-Bicuit I tried opening slowly with grill valve off no solution. I leave it connected for 15 min and when I disconnect I get just a small spit of gas sound. Less than when I disconnect the small bottle.
Oldcoots I really don't want to remove the regulator if not necessary. Then I would not be able to use my small tanks, right?
Think I will try and call OGrill. Their website shows a hose as an accessory but no explanation or part number. Maybe I just need their hose or at least a different brand, even though CW says this one will work.
Thanks for all the replies, will post if and when I get a solution.
Was hoping someone with exact same grill was out there with a solution.
B.O.
Looking for advice before your next adventure? Look no further.25,106 PostsLatest Activity: Jan 26, 2025
