wing_zealot wrote:
I believe that is the way all the 2 1/2 inch drawbars work. Check this out, you can clearly see a piece on each side to make the 1/2 inch difference while the drop part is smaller. clicky
well well well! You might be onto something here... You're right, I totally agree about the extra 1/4" either side of the receiver side of the shank.
thanks very much. My time at etrailer was always in the "reese" product lineup, or "curt" for the hitch. I had not ventured into other product lines.
this is likely the direction I will go.
Thanks for your help and searching.
