nharinton
Sep 18, 2019Explorer
1L243 wrote:
It seems that there is a lot more going on there than over tight saddle brackets. I see where the saddle bolt was tightened down too tight but the top of the frame looks distorted as well. I'm seeing alot of rust. I assume that is a box frame? considering the age of the trailer, I would be concerned that the frame is rusting from the inside and the metal is weakened.
I would have the entire A frame replaced by a professional welder. Not as expensive as you might think.
Any idea what your tongue weight is?
The rust is nothing more then surface rust. Its pushed up becase the whole frame was squeezed by the saddle bolts and then driven so they twisted
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
