twodownzero
Sep 18, 2019Explorer
nharinton wrote:twodownzero wrote:
I would probably leave it the way it is. It's a shame that someone did all that damage. If I wanted to fix it, I would probably drill and tap the other side of the frame and use a large diameter bolt to "push" the dent out and then weld the hole closed, grind smooth, and paint.
Why not ainpky patch it up?
Because thickening and strengthening the frame in that one spot is going to create a stress riser that could potentially cause more problems than it solved. I'd cut out the entire section and weld in a patch of comparable thickness before I'd plate over it and create that stress riser.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
