- WoodtrollExplorerI have read about these for several years now, and would like to try one. I've looked all over the Good Sam website, and can't find the $5 coupon mentioned even after I logged in with my membership number. Can someone point me to the right place, please? The sale is advertised as an "Internet-Only Special"; wil the store honor the $29.99 price?
Thanks very much! - wbwoodExplorer
Carb Cleaner wrote:
It appears the coupon is qualified, "Not valid on CampingWorld.com."
Also, "Coupon must be mailed in for final redemption. Discount applies to merchandise only. Good for one time use only. Limit one per customer. Offer Expires Feb 28, 2014."
(from GoodSamClub.com)
Good luck.
Ahhh..used mine in the store. - Carb_CleanerExplorerIt appears the coupon is qualified, "Not valid on CampingWorld.com."
Good luck. - wbwoodExplorer
EPenney wrote:
Awe man...you guys made me go and order one today from CW.:B
CW has a sale going on right now on the Oxygenics Shower Head. $29.99 + S&T brings it to $38.54 delivered.
You should of used the $5 off coupon! - wbwoodExplorer
tenbear wrote:
CavemanCharlie wrote:
When I look this up on Amazon it seems there are several different kinds. What kind are most of you using in your RV?
Here is a link. I have an older version of this one. I use the old existing holder and I replaced the valve with one that is continuously variable and completely shuts off.
Better link to it. On sale for $29.99. Shipping is $9.00. And I just checked, there is still a $5 off coupon for Good Sam mmebers. So, you can get it for $24.99 plus the shipping. - EPenneyExplorerAwe man...you guys made me go and order one today from CW.:B
CW has a sale going on right now on the Oxygenics Shower Head. $29.99 + S&T brings it to $38.54 delivered. - tenbearExplorer
dgcarver wrote:
Maybe the trickle flow allows the hot water to stay hot? On my factory supplied one, when I shut off the flow for a few minutes to soap down, the water is cold for a few seconds when starting to rinse. It that the same with the Oxygenics when you use a complete shut off?
I have heard the same thing. Some people say it gets hotter with the water shut off, it depends on the plumbing. The same thing happens with a shut-off valve. I usually hand hold the shower so I just point it away for a couple of seconds after turning the water back on. - dgcarverExplorerMaybe the trickle flow allows the hot water to stay hot? On my factory supplied one, when I shut off the flow for a few minutes to soap down, the water is cold for a few seconds when starting to rinse. It that the same with the Oxygenics when you use a complete shut off?
- CavemanCharlieExplorer III
nohurry wrote:
Ron3rd wrote:
They also have a new model with built in shutoff.
It's not actually a shut-off. The description says it "Allows you to pause the flow to a trickle". I have this on our short list to get, but I'll probably install a shut off from the hardware store.
There is some law, for some reason, that states that the valve on the shower head itself is not allowed to completely shut off. - gmctoymanExplorer"Search and ye shall find", or something like that. Just in case you miss the search function here are the results it comes up with....
Click thing
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 11, 2025
