FunnyCamper
Feb 02, 2018Explorer II
Here is some info:
Destination trailers are the ideal choice when you’ve found your special place at the end of your RVing road and you’re ready to settle in for a season, several months or most of the year.
Taller, heavier and more homelike than most travel trailers, destination trailers are for recreational vehicle owners who plan to make a drive to their special place by the lakeside, in the mountains, or at the beach – and stay awhile.
Defining Destination Trailers
Weighing in at about 10,000 lbs, destination trailers, unlike travel trailers and fifth wheels, are designed with long stays – not long drives — in mind and do not have the lighter, more aerodynamic features RV enthusiasts seek in standard bumper-towed or fifth-wheeled travel trailers. However, unlike many other RVs, a destination trailer does not need to be towed by a commercial vehicle and is not “tied down” at a campground or park.
Destination trailers are advertised under many names: villas, cabins, residential trailers, retreats and resort trailers, even oil-field housing, and frequently, park models. While the names may vary by manufacturer, some features distinguish destination trailers from true park models and travel trailers.
Weight, length and design distinguish destination travel trailers from standard bumper-towed travel trailers. Set-up, size and hookup are among the features that separate destination trailers from park models.
Narrowly defined by the Recreational Vehicle Association of America in 2012, a park model cannot exceed 400 sq. feet and generally has the hitch assembly and wheels removed and a skirt installed once it reaches its site. A destination trailer is leveled and set up like a standard travel trailer and the hitch remains in place.
During set up, a park model will be hooked to a residential water and sewer system; black water, grey water and fresh water holding tanks are not standard equipment on park models. Destination trailers are self-contained and can either use campground hookups or rely on their standard equipment holding tanks.
Additionally, park models may have permanent, attached decks, patio covers or carports, while a destination trailer usually has an RV-style retractable awning. As transportation is not an issue, many park models are over 8 feet-6 inches wide and require a trip permit and commercial transit. Though heavy, destination trailers can be towed by most properly equipped one-ton trucks.
park models and destination trailers are not truly for 'long time on the road' all the time highway/road travel. Travel RVS are for traveling for many reasons. Other models are more for parking, staying put BUT CAN be moved for travel to another destination.
well that gives some insight :)
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
