Ron_Gratz
Dec 08, 2013Explorer
Brngrhd wrote:Without WD, the entire 1000# tongue weight will be carried on your TV.
How does that all play out? If you have 1400lb payload and 1000lb tongue weight that leaves 400lbs for passengers and other "stuff" if your hitch moves 300lbs back onto the TT does that free up 300lbs of payload?
The WDH does not create load -- it only transfers loads among the axles.
If the WDH is adjusted to transfer 300# to the TT's axles, then the amount of load transferred to the TV is only700#.
That frees up 300# of TV payload.
Ron
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 04, 2026
