mobeewan's avatar
mobeewan
Pinkish-orange algae in water lines
I have the translucent pex tubing that you can see through that is like the plastic in milk jugs. There is as light pinkish orange discoloration on the inside of the tubing. I believe it to be the same algae stains that are around the edge of the tub. I plan on doing a good cleaning of the trailer soon and will be winterizing. I was thinking of using the winterizing connection and adding either dilluted peroxide or straight white vinegar into the lines and soaking for a couple days before flushing and sanitizing and then winterizing the water ststem. I would like to dissolve any organics in the tubing to get rid of them. I know bleach will sterilize everything but i also want to remove any deposits left in the tubing. Any recommendations from anyone that has done anything similar? I'll be doing the cleaning the FW tank too.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 12, 2026
