time2roll
Sep 16, 2018Nomad
luberhill wrote:
Ahh ok so. 59 amp IS a 220 double pole breaker ??
And if you have a 50 amp supply but only a 30 amp MH isn’t that pumping too many amps into the MH ??
Yes.
No. The 30 amp RV only pulls what is needed to the limit of the main breaker in the RV.... 30 amps. Consider what happens when you plug a lamp that takes 1 amp into a 15 amp outlet. (normal operation)
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
