wa8yxm
May 27, 2014Explorer III
I would say 90% of all RVers have your problem.. I just ignore the beast.. My tanks have other ways of saying "DUMP, SOON".
There are 3 or 4 different sensor sets.
Standard is a row of nails, or equivlant of nails, these penetrat the tank wall, Just a metal rod inside the tank, if the rod is WET, then clearly the level is at least that high. The "Gauge" senses which rods are wet and shows the level.. The problem is that slime on the walls keeps them wet all the time.
HORST miricle probes are "1b" for this discussion, Same type of sensor but they have done a few things to make them less suspectable to slime.. Supposed to be good, I hope to install later this year.
There are Pneumatic sensors.. These measure pressure at the sensor point, if the pressure on both sides of the sensor is the same, It's not that full, If the pressure is higher INSIDE the tank, it is that full... I have only seen these in the instruction manual for my macerator toilet. alas the sensors were NOT installed.
In theory you could weigh the tank. Several companies make load cells that could do this.
SEE LEVEL sensors use some sort of electrical sensing to measure the level inside the tank.. People who have this type of sensor.. Say it works well.. The only problem is if the sensor falls off the tank These are the Cadillacs of the sensors.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
