wa8yxm
Jul 15, 2014Explorer III
Fishinghat wrote:
You used so much amperage out of your batteries on the first day that your generator was working hard to recharge. Then you put an additional load on the generator when you used the microwave.
You sir,, have been reading my posts it seems. That is my diagnosis as well.
IF you have a magnetek 6300 this does not apply but if you have a decent 3-stage converter,, You bet'cha as one failed politician might say.
Last Campground I was at I had 30-30 electric service (two 30 amp breakers) one fed the rear A/C and the Progressive Dynamics 9180 with wizard both of which, on my rig can be operated "Independent" of the house 120 volt system.
Well if I'm doing heavy cooking with both A/C running I can easily pull close to 20 amps in the kitchen.. So Id shut off power to the inverter and cook off batteries.. IF I did that long enough the 9180 went into BOOST mode and started sucking enough power that with the 13.5 draw up on the roof.. click went the breaker.
When we lived at home I had a 20 amp feed to the RV. Never could get wife to understand you do not turn on A/C or Water heater for at least 2 hours (or Microwave) after plugging in. Let the batteries eat first.
Looking for advice before your next adventure? Look no further.25,198 PostsLatest Activity: May 25, 2026
