- twaltonExplorerIt turns out that my problem was not the controller but a short in the positive voltage line. be sure to check incoming voltage before you spend $1400 on a replacement. as always, thanks for the help.
Tom - wa8yxmExplorer IIIThanks I man need one myself.
Also if you can find the relays (I can) another forum member designed a "Manual" replacement
Look for a thread about High Voltage drop to slide out motor It is in there.
I'd add limit switches to his design, but I may go that route as well. - 1492ModeratorMoved from Forum Technical Support
Looking for advice before your next adventure? Look no further.25,196 PostsLatest Activity: May 16, 2026
