Hello, Can someone tell me why when I plug my electric candle warmer in, in my RV it does not work properly? I bring it home and it works fine. Thank you Jody
It sounds like the electrical outlet you are plugged into is not working. Try plugging another item into the same outlet and see if it works. If not, you need to troubleshoot the circuit to see why it's not working. It could be a GFI switch or circuit breaker has tripped.
Jim
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 17, 2025
