EstorilM's avatar
EstorilM
Power outage, moving into TT - tractor to charge 12v?
Power is probably going to be out for a few days. Generator is at my parents a few hundred miles away (yeah, not convenient) so I'm on my own with 12v.
I have a second marine deep cycle, but that's only going to get me so far with the propane furnace blower, etc.
Two questions - one, I have an 800w inverter but I'm not sure how to hook this up in this case. I would just plug the RV into it and keep my power usage down, but I would need some way of bypassing and disconnecting the power supply/battery charger.
I'm guessing the most efficient way to do this would be to run large gauge 12v wires inside the TT and run the inverter off of batt directly/separately, then only plug in the few 120v things I need (ie not use any of the TT's 120v systems).
As far as keeping the battery charged, I have a diesel tractor - do you think the alternator generates enough current at idle to charge up the batteries? I'm thinking I'd just run the two deep cycles in parallel then run the tractor every now and then to charge them back up. I should be fine at night as it's just the furnace blower that would be running.
I could always use the LR3 as it has a 160A alternator and a huge battery, but nowhere near as efficient. I could run the diesel deere on a couple gallons forever (and it's obviously made for idling anyways).
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
