Kountryguy's avatar
Kountryguy
Prest-O-Fit Sewer Hoses
Those of you who use this sewer hose system, how do you secure the fittings in the ends of the hoses?
  • You just push them together and they stay. If you can just pull them apart easily, you're not pushing them together tight enough. I have to give them a little twist to eaze seperation. I've been using them for more than 10 years and have never had them slip apart in use.
    I started using them because they fit better in my storage spot better than the conventional type.
    Or are you saying the factory end came off? If so, it's bad.
  • The reason for my question is, I just purchased o new hose and I am able to pull the connectors right off. I have never had this happen before. One of my older hoses has a cracked fitting on one end and I want to replace it. Wondering if I use some adhesive caulk, that would work. Don't want any "surprises" !!
    The fittings are glued into the hose. I have been using them for a number of years and have never had one come apart nor have I had the slip together joints come apart while dumping.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 02, 2025
