hbillsmith
Dec 22, 2014Explorer
The short answer is that any hitch's weight will reduce the amount available for the trailer. If you receiver is rated 800# and your chosen hitch weighs 200#, you will then have the remaining 600# available for the trailer. The amount for the trailer will include at least the advertised trailer tongue weight. Let's say the trailer's advertised tongue weight is 500#, in this example you'd have 100# left to use for increased tongue weight coming from your stuff.
The only 2 ways I know of to manipulate this is A) choose a lighter hitch and B)adjust/balance the load inside the trailer. With option B) you have to be careful not to make the trailer rear overloaded/heavy.
If you have the trailer and tow vehicle you can visit the CAT scales and with 3 passes, you can get all your answers. Pass#1: Tow vehicle loaded for trip with all passengers and fuel and trailer attached with WDH on and in force, Pass#2: Same setup but disengage the WDH chains or bars, Pass#3: Drop the trailer in the lot and just weight the tow vehicle.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
