Ron_Gratz
Dec 27, 2014Explorer
LarryJM wrote:Larry, your statement is incorrect. You need to re-read what Ron posted.
---The argument that the hitch is not part of the tongue wt. is something that even Ron disagrees with and he even adds some of the HA/PP hitch wt. to the tongue wt.---
I can appreciate what that document Ron referred to, but it's not IMO univerally use and is woefully out of date with the last revision being almost 40 years ago.---Well, you're welcome to your opinion -- but I think all the manufacturers who continue to rate their towing equipment based on VESC-5 and its SAE look-alike, SAE J684, would argue that the VESC-5/SAE-J684 testing protocol IS universally accepted for its intended purpose.
The only criticism I could find of VESC-5/SAE-J684 is that it only covers trailers up to 10,000# GVWR.
The need to have a rating system for heavier trailers is discussed in How Hitch Manufacturers Are Designing Class-V Hitches To Extreme Capacity Levels
However, the bottom line is that VESC-5/SAE-684 specifies that WDH test moments are based on trailer tongue weight and NOT on tongue weight plus the weight of the WDH.
Ron
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
