Flapper's avatar
Flapper
Pro-Pride "tuning"
Got the new 3P installed per directions. Trailer had to go to dealer for some other work, so got to do a 60 mi. road test, with 20 mph tail or quartering winds.
As advertised, the previous sway I had experienced was gone. Things were still a little "wiggly" (which may just be wind gusts), and there was a bit of "suck" from semi's passing me. That may have been more of the semi's blocking the wind, than actual "suck". Nothing at all bad, and I would be very happy driving long days as-is, but wondering if there is a bit more fine tuning I might be doing.
Hitch height currently has trailer 1/4" (at the hitch) nose high of being level. Height adjustments are in about 1 1/2" steps.
Hitch ("stinger") angle is 1 washer - dead straight on to the socket when hitching up.
Current WD is set to bring front fenders back to unloaded height, still have lots of adjustment left to transfer more to the front (will scale it when picking up from the dealer in a few days).
I've had several prior threads about "towability", so can move on to trying other things (tire pressure, tongue weight, etc.) - but if there are suggestions about optimizing the ProPride itself, I'd appreciate hearing them.
  • I should make clear - this truck came new with 17" tires, LT, LR "E". They were Goodrich AT's. After 70,000 miles it was time, so switched to Michelin Defender LTX. From scouring the net, these seemed to be well liked by RV'ers and seemed to be better for the ice/snow daily driving Minnesota can throw at one. Of course, 3 months after purchase, I begin to hear that they aren't the best for sidewall stiffness. Load inflation tables for these don't seem to exist. In talking to Michelin, and the help person looking things up, very similar tires from them seem to recommend going about 10 psi above door sticker for the load I will be carrying. So, from 55F/60R to 65F/70R. Max is 80, so still within the margins.
    I do have airbags leftover from when I had a fifth. But there are no plans to add them to the mix, so will just continue to air up to the 5lb minimum noted by Firestone.
    The order of battle, when I get the TT from the dealer, will be: Make sure tire pressure is at sticker when I leave home. After picking up trailer, stop at the nearby scale and get weights. Air up all tires 10 lb above whatever they read at the truck stop. See what happens on the 60 mi ride home. If possible, check hitch tracking while on the way.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 17, 2025
