Flapper's avatar
Flapper
Pro-Pride "tuning"
Got the new 3P installed per directions. Trailer had to go to dealer for some other work, so got to do a 60 mi. road test, with 20 mph tail or quartering winds.
As advertised, the previous sway I had experienced was gone. Things were still a little "wiggly" (which may just be wind gusts), and there was a bit of "suck" from semi's passing me. That may have been more of the semi's blocking the wind, than actual "suck". Nothing at all bad, and I would be very happy driving long days as-is, but wondering if there is a bit more fine tuning I might be doing.
Hitch height currently has trailer 1/4" (at the hitch) nose high of being level. Height adjustments are in about 1 1/2" steps.
Hitch ("stinger") angle is 1 washer - dead straight on to the socket when hitching up.
Current WD is set to bring front fenders back to unloaded height, still have lots of adjustment left to transfer more to the front (will scale it when picking up from the dealer in a few days).
I've had several prior threads about "towability", so can move on to trying other things (tire pressure, tongue weight, etc.) - but if there are suggestions about optimizing the ProPride itself, I'd appreciate hearing them.
  • Somethings definately amiss if you're having any sway or push-pull using a PP with your F150 HD. That truck should have no problem towing that TT.
    Is the truck moving or just the TT waggling some?
    I towed a 31' 7200lb TT with a Max Tow 145" WB F150 using a Hensley Arrow and had zero push pull.
    Only thing I can imagine is that with your TT you have too light of a tongue weight. It comes from the factory with a marginal tongue weight, then most all the heavy stuff is back of the axles.
    Have you ever weighed the tongue?
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 10, 2026
