danewguy's avatar
danewguy
problem with tow electric hook up on Georgie Boy
Hi all ,
I have a 2007 Georgie Boy Landau on a ford chassis, recently I purchased a new toad (jeep wrangler) and I have spent most of the day trying to get things set up. The jeep is all wired with a Cool Tech plug in wiring harness and before putting the connector (in front) on I wanted to make sure the wires are proper. I took a test light to the connector on my RV with the blinker on and I am not getting anything showing power in any of the pins. I crawled under the rig and traced the wires back to where they go into the main wiring harness and they look ok. I spoke to my local RV repair guy on the phone and he told me to check the fuse panels, from what I could see all the fuses were ok (there were like 5 that had to do with towing) I am really frustrated and losing my cool. Has anyone else experienced this? a 12 volt test light should light when placed on the pin correct?
Some one help please!!!!!!!!!!!!!
Moved to Dinghy Towing forum from Towing.
  • Thanks for your responses. I checked fuses etc and it turned out to be corrosion. So I cut the wires back purchased a new connector and installed it and everything works great. Thanks again for your help I needed to step back and take a break I was getting crazy with the heat etc.
  • I have a 2007 Georgie Boy Landau on a Ford chassis also. On ours, the trailer wiring receptacle was not wired from the factory - just loose wires bundled up by the hitch. So, chances are the receptacle was wired at the dealer or later. In 6 years, I can almost guarantee you that the wiring and connections are corroded on the back side of the receptacle.
    Do what I just did - remove the receptacle, cut the wires back 6 inches, test for voltage and then put in a new receptacle. For $10 it is much easier than trying to troubleshoot.
  • danewguy,
    First off, in just about any electrical test with a test light, always make sure that the ground that you're clipping the ground to is a good, clean ground. I've done that more times than I care to admit. Testing, testing and testing and no light. Come to find out, the ground I was on was not a good ground. Also, I ALWAYS test the light, right on the battery terminals to make sure the light is functioning fine. Nothing like trying to find a fault with faulty testing equipment.
    So, once that's established, then yes, a test light should reveal the function of each of the pins. I always start out with the running lights. It's just a preference, there's no real pattern. I also draw a picture and label each pin for function.
    Now, if you're not getting power at every one of those pins, then one, it's possible that the back side, where all the wires enter the pins could all be corroded, not likely but, possible.
    Second, there's another plug/connector some place in the wiring that connects that harness to the main harness of the coach/fuse connections. Now, you say you've found the fuses for the trailer plug and they "appear" to be OK? You can use your test light on them too. Just make sure you've got a good ground and then touch the exposed metal part of both sides of each of those fuses. Sometimes, the fuses may make a bad contact and or, are broke internally and they appear good but, in fact, are not.
    Now, once you've determined the fuses are good, then you'll have to start tracing those output wires, and possibly "probing" them once in a while to see if you've still got power. You'll do this all the way to the trailer plug on the back. Hope this helps some.
    Scott
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 13, 2025
