dee74
Oct 20, 2015Explorer
FLY 4 FUN wrote:
Have you ever had the auto-switchover work before on this rig? Sorry if this sounds silly but you do understand that the valve does not physically move during switchover....it merely determines the primary tank. Once you know that the tank is empty...and its properly swapped to full tank you can physically flip the lever, and then disconnect the empty tank to refill. I also suspect that the overflow preventer kicked in and you had a full tank that wouldn't let you have any flow.
This was the first time the primary tank was empty. On my last tt the propane just switched over and I did not need to do anything. I knew the tank was empty when the indicator was red so I would flip the switch and fill the empty tank.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 29, 2026
