wa8yxm
Aug 27, 2023Explorer III
Though I agree with the suggestion to put in a proper multiple outlet RV panel.
If you plan to upgrade I'd recommend at the MINIMUM a 50 amp outlet.
You can use 30 amp breakers (And upgrade later) if you wish that would be (if you know how to change breakers) cheaper than the full 3-outlet panel. but I agree the 3-panel will do find.
I went with a 30 amp outlet fed by a 20 amp breaker for my rig and for home use. it was fine.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
