valhalla360
Aug 28, 2023Navigator
Just put in the 50amp lines back to the panel. The cost to run and connect a 50amp vs 30amp cabling is negligible but it sets you up to handle anything.
Then you an choose:
- Just a 50amp outlet and use a dogbone (saves a little money but not much)
- Put in an RV park style pedestal that has 50/30/20amp outlets (all connected up to the same 50amp cabling which is not an issue).
I would lean toward the RV park style pedestal. That way you don't need adapters and if you need to plug in a power tool or something, you can just plug it into it's own outlet rather than running it thru the trailer electrical system first.
Then you an choose:
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
