pianotuna
Aug 30, 2023Nomad III
StirCrazy wrote:Bobbo wrote:
Are you trying to say you ran a 4 wire, 120/240v circuit to a box, and put a 30 amp RV on one leg and other outlets on the other leg? Because, if so, merely saying you have a 30 amp RV service does not convey that information. As a matter of fact, the phrase "30 amp RV service" strongly implies a 3 wire, 120v installation, not having 2 legs.
I do believe that's what he is saying, but He ran a three wire, you don't count the ground. normal house is two wire, 240V is three wire, I know it's weird ha-ha
No.
I use a 'break out box' that has a 50 male plug, and a 30 amp female on one leg and twin 20 amp female on the other leg. Each outlet has its own breaker.
I do have a total of 3 shore power cords. The OEM 30, a 20, and a 15. I used them during extreme heat and extreme cold.
I used to do "double conversion" when there was only a 15 amp shore power outlet. I plugged in only the converter to shore power, and then plugged in the OEM shore power cord into a 2500 watt Cobra inverter (rated for use with electric motors).
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
