longislandcampe's avatar
Aug 26, 2023
Proper Power Receptacle For Home?
We always kept the TT in storage but now keep it in our side yard. We use the 30a to15a dogbone but we will be having the proper receptacle put in place so we don’t have to bother with extension cords and adapters anymore.
We currently have a 30a TT but will be upgrading to a larger one when the kids are out of daycare, but that’s still like 4 years away.
Our electrician is a camper so I’m confident in his work but I don’t want to bother him until we are ready for the work.
Let’s say we wanted to have a 30a and a 50a receptacle installed. We would use the 30 now and the 50 when we finally upgrade down the road. Would we need a dedicated 50a line AND a dedicated 30a line run to their respective receptacles by the camper? Or would we only need one dedicated 50a line and then they’d splice the line behind the receptacles to feed the 50a and the 30a receptacles? We wouldn’t be using the 50a and the 30a at the same time.
We do have a 50a to 30a dogbone just in case the 30a receptacle at the campground is down.
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    nickthehunter wrote:
    All you need is the 50A line and the 50A and 30A receptacles can be run off that. I am not up on the code for that but it may require you to change the receptacles and breakers when you change to a 50A RV.
    TT 50A is a 240V/50A 4 wire circuit with two 120V/50A legs, two hot, one neutral one ground.
    30A is a 30A/120V 3 wire one hot, one neutral, one ground.
    If you plan to eventually go 50A, have the system wired to support both. A 50A/240V 4 wire from the main breaker box feeding the "trailer box". That box will be like what you see in campgrounds with one 50A/240V breaker and usually 2 120V breakers, a 30A feeding a 30A RV outlet a 20A/120V feeding a 20A duplex outlet and a 50A/240V breaker feeding the 50A outlet.
    Note: The trailer will use the 50A 240V as TWO 120V/50A circuits, I don't know of any trailer that actually have any 240V appliances, although it would be possible to do.
    Just make sure the don't wire the 30A as a 240V circuit!!!
    https://www.homedepot.com/p/GE-RV-Panel-with-50-Amp-and-30-AMP-RV-Receptacles-and-a-20-Amp-GFCI-Receptacle-GE1LU532SS/203393689
    Or just install a 50A circuit and use a 50-30 dogbone, Later if you decide you want a 30A outlet it can be added
    Don't start with 30A, you'll basically redo everything going to 50A.
  • An RV electrical panel like this is best way to go. Wire from your main electrical panel with wire correctly sized for the distance. Number 6 would handle the load.
  • All you need is the 50A line and the 50A and 30A receptacles can be run off that. I am not up on the code for that but it may require you to change the receptacles and breakers when you change to a 50A RV.
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Feb 20, 2026
