JIMNLIN
Nov 01, 2016Explorer III
Snipped from Tireman9 rvtiresafety.com blog;
*When not driving in a straight line there are special side loads on multi-axle trailers because the tires are fighting each other because they are not "pointed" to the center of the radius of the turn. These loads cause interior structural tearing. Sometimes 24% higher loads than those seen in tires on non-trailer application. Initially tearing is at the microscopic level but with time and repeated cycles these forces grow which can lead to small cracks at the belt edges as seen here at the arrows.*
and
*You can lower these forces by either decreasing the load 24% on the tire (probably not something you want to do or may not be able to do) or you can increase the inflation to stiffen the structure and decrease the slip-angle. In this case you could increase the tire inflation from the minimum inflation needed for the static load to the inflation associated with the max tire load as molded on the tire sidewall.*
Also add the fact ...many trailers can weigh more on one side than the other. Using a pressures from a minimum pressure chart may cause the tire(s) on the heavy side to run over loaded.
A severally over tired trailer has its own problems with the best psi for the good of the tire.
and
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 28, 2026
