retire7's avatar
retire7
protection for car
Has anyone used the protect-a-tow with a car dollie? I don`t see where it could attach. Has anyone seen a similar device for a car dollie. Thanks
  • Waste of time and money
    towed 40,000 miles in the past 5 years no problems with the Honda or the newer Jeep
    Why assume others will have the same result as you? On our first trip with the short overhang motorhome and a low to the ground car, there were hundreds of paint dings in the car's lower fascia. Protect-a-tow has mostly solved the problem except for occasional "leakers" at the edges.
  • I've been using a Protect-a-tow for several years over my dolly. The front attaches to the rear bumper of the MH and the rear uses two bungee cords attached to large S hooks mounted on each side of the dolly. See below:
    It does not fully reach the toad but is seems to keep most of the larger stones off the toad and really keeps the MH rear & camera clean. I think Protect-a-tow sells a longer model that might do an even better job but I’ve not needed to replace mine yet. I have a Demco KarKaddy and there were two holes on the wheel plates that the S hooks fit into. I don't know what king of dolly you have so I can't suggest how you would mount yours.
    Dave
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 06, 2026
