Yosemitebobr's avatar
Yosemitebobr
Purging air from the water pump - How to
OK, so I have a new pump, but now it is making a heck of a chatter, beyond the pumping noise. I assume it is air, so how do I purge the air from the filter/lines. It doesn't seem to go away just by running it, just keep chattering.
  • You need to tell us what make and model of pump you put in.
    Some just are VERY noisy......and how they are mounted makes a difference too.
    If the noise you hear is a loud growling sound within a second or two after turning OFF the water flow, that's probably normal. Most I've heard are fairly quiet when the water is actually flowing.
Looking for advice before your next adventure? Look no further.25,164 PostsLatest Activity: Sep 20, 2025
