tim1970's avatar
tim1970
question about black tank rinse
My 5th wheel has a built in black tank rinse. My black tank is 32.5 gallons. Once I empty my black tank I would like to be able to close the valve and turn the rinse hose on for a few minutes to help clean out the tank. However, I am not sure how long to let the tank fill. I definitely do not want to overflow my tank. I realize all water sources have different flow rates, but is there a general guideline that I can follow? I am guessing about 1 or 2 minutes before opening my valve again.
  • I don't have a fancy back filler. But I have ran a water hose into toilet and used a Flashlight to see when its almost FULL.
    the sound of the water changes when its close to the neck
  • First, I leave the rinser running while the tank is draining. Then when the bulk of the contents have drained, I close the valve, leave the rinser running, and watch the black tank level indicator inside. When the full LED barely starts to blink, I hop back outside and open the valve. I only do this every few months (we're full-timers). In between, I use the "geo method" to clean the tanks on a travel day (dish soap, borax crystals, and about 1/4 tank of fresh water in each tank before hitting the road).
    Rob
  • You'd be hard pressed to find the volume at a campground that's more that 10 GPM, so a couple of minutes would be safe.If in doubt, take that 5 gallon drywall mud bucket you have in the basement with you and time how olng it takes to fill that up. Last time I checked at my house, good pressure municipal water was 6 GPM.
  • I go one to two minutes. I hooked up a water flow meter a couple of times to test, and in about two minutes, I get 4-5 gals. Initially I might just go a minute, but after a couple of times, I'll go for two mins or maybe even 2.5 mins. Of course, when Im doing three or four or more flushes, it's at a FHU site, or a dump station with no one in line.
    Mike
  • I never go more than 30 seconds, mainly because there's this big warning sign on my coach.
