pnichols
Sep 07, 2020Explorer II
RobWNY wrote:
If you're in an RV and truly have flames licking your a$$ it's not going to matter if you can find the dead bolt or not. It will be too late by then. RV's go from on fire to fully engulfed very quickly. Now if your smoke detector goes off and you can't get through the window, a good swift kick of the door or a hard shoulder into it will get the door open. Those dead bolts aren't hard to get open. You have very little time in an RV if there's a fire. You get out by any means you can. It's not like the RV is going to be salvageable anyway so no need to worry about damaging anything.
Yeah ... and I've always wondered about your "RV's go from on fire to fully engulfed very quickly" comment ... that seems to be true.
Other than a steel propane tank and a motorhome's steel fuel tank (both of which probably don't catch fire initially or at all) and interior wood cabinetry, what is so flammable in an RV, anyway?
Other than the above, our motorhome consists mostly of fiberglas, foam insulation, steel, and aluminum.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 21, 2026
