Aka_the_breeze's avatar
Oct 27, 2020
question about freezing temps
Our highs are all in the low 60's early week, then mid 50's.. with lows right around 50 until Friday, then it is forecasted to be 29... Saturday back to 50 with the highs averaging mid 50's and lows averaging mid 40's..
We have not winterized yet, hoping for extended trips this year... Should I be worried about that 1 night?
Am I crazy for even asking?
  • Mayor30 wrote:
    The answer is no. One night of freezing temps isn't a worry. It's when you get multiple days with wind that will freeze your pipes.
    Care to share the physics behind that?
    No, if it's cold enough to freeze, one night is enough. Wind can speed it up a bit but if it's only a couple degrees below freezing, it makes less impact than you might think (wind can be a real issue when in colder weather and you are relying on the heat from the furnace to keep everything thawed).
    To the OP:
    - How reliable is your weather forecast? If it's really 29F and it only drops below 32F for an hour or two, it probably won't be long enough to freeze but it's a **** shoot.
    - If they are off or you are in a low spot where it gets down to 25F and holds for 3-4 hours, freezing is likely. The main tank probably not going to freeze as there is too much mass but lines and fittings don't have the same mass, so they can and will freeze more quickly.
    If it's convenient to your house, you can just turn on the furnace and set it for something like 60F, that will bleed off enough heat that it should keep the lines from freezing while using negligible propane if you don't want to do a proper winterization.
    One item to watch is the Black/Gray drain pipes. If they are exposed, heating the trailer won't do much for those, so it's best to drain those tanks fully, so there is nothing sitting in the exposed pipes.
  • down home wrote:
    We had a few nights of freezing temps in Az and ice in the fresh water supply hose. Flushed out after a minute or two but... one of the heated hoses with 110 plug is in order. Price of over a hundred to over 200 according to length galls me though. I know I can use from the tank and refill during thee day but that's another chore...when it is cold outside! We had installed a 50 amp box at wife's Sisters for our stay but not a 110...so I'm thinking of getting a tech to run a 120ac plug from the other side of the coach that has two or three in the bays. May need a separate wire an breaker though as intend some sort of small forced air heater with weather tight or resistant housing and thermostat to make sure the tangs are warm and the wet bay. Just need the layout and drawing it up before any cutting etc. Would also come in handy going down the road. The furnaces heat the bays some but...
    ***came cross this MH Service Bay Heater: 12volt apparently with plug
    List several MFGs that use it or that it will fit.
    https://shop.findmyrvparts.com/wet-bay-heater-service-bay-3000rv-monaco-rv-parts-p/3000rv.htm
    don't fully understand your post, but if you have a 50 amp hookup, you have 120 available
    bumpy
  • We had a few nights of freezing temps in Az and ice in the fresh water supply hose. Flushed out after a minute or two but... one of the heated hoses with 110 plug is in order. Price of over a hundred to over 200 according to length galls me though. I know I can use from the tank and refill during thee day but that's another chore...when it is cold outside! We had installed a 50 amp box at wife's Sisters for our stay but not a 110...so I'm thinking of getting a tech to run a 120ac plug from the other side of the coach that has two or three in the bays. May need a separate wire an breaker though as intend some sort of small forced air heater with weather tight or resistant housing and thermostat to make sure the tangs are warm and the wet bay. Just need the layout and drawing it up before any cutting etc. Would also come in handy going down the road. The furnaces heat the bays some but...
    Motorhome Service Bay Heater
  • The answer is no. One night of freezing temps isn't a worry. It's when you get multiple days with wind that will freeze your pipes. You can always drain your lines and throw anti freeze in the traps if you're worried.
  • Our temps here will be somewhat similar and I am not concerned.... I was camping last weekend and still have all my lines and water heater full....
    If your truly concerned, you can always turn on your furnace that night and leave it set at the lowest setting... 40*..50* .. For Me, don't wast the propane..
    By the time the temps around the lines get to freezing, the outside temps will be rising again...
    Don"t Worry, Camp On !
Looking for advice before your next adventure? Look no further.25,163 PostsLatest Activity: Sep 05, 2025
