DutchmenSport
Nov 03, 2013Explorer
The Adco covers have zippers in the side so you can unzip a section and still have access to the door. Depending upon where your slide is, compare it with an actual cover. Apart from this, I don't know of any covers designed to accommodate the slide in the extended position, as almost every camper has a different configuration, it would be an impossible feat for even the best of companies to manufacture. Check into the covers with the zippers designed for access. I've had 2 covers for 2 trailers now, from Adco, and both had different zipper configurations.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
