YC_1
Dec 15, 2017Nomad
Diodes add many more connections and potential bad connections. Water intrusion can be an issue too.
If the brake device is sensitive to input voltage it could be fooled by the tiniest of voltage leak and either stay locked up or worse, some can lock up while you are driving the toad.
I highly recommend using separate bulbs which are easy enough to install or stick with your magnetic setup. Another option if you have a tow hitch on the toad it so to use a tow bar with or without a tow ball and then connect a cross bar to hold lights on each end. The light bar can be removed easily. I often just leave mine in place. The tow ball is still available if needed.
Looking for advice before your next adventure? Look no further.25,202 PostsLatest Activity: Jul 21, 2026
