Dutch_12078
Dec 24, 2017Explorer III
I used diode packs in both our current and previous RAV4 toads, in fact, the same diode packs. I found the simplest place to install them was behind the driver's side kick panel where all the rearing wiring is routed. That saved having to run wires all the way to the rear, and also made it easy to fully light the car when in tow. The directionals use the amber lights and the red lights for the brakes as expected. Even the high center brake light works as it should. The Toyota dealer we bought our then new 2011 RAV4 from had no issues at all with the towing mods, including the lights and Remco lube pump, as far as any warranty issues.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
