DSteiner51
Mar 14, 2017Explorer
Being you live out in the country I suspect you have your own septic system. If so, where is your opening for cleanup?
When I get home and the black tank is fairly full before I park it I will pull up somewhere close to the system and dump it with the normal 3" hose. If it is either too wet to pull in or parked for a while and being used I use a Flojet Waste Macerator and a 3/4" garden hose to reach the septic. Works either way.
If working outside, the camper is closest and the bathroom just inside the door a couple steps it makes much more sense to use the camper then the house bathroom for a quick pit stop. Been using this system for 17 years and no problems.
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
