Hiker_01
Feb 27, 2016Explorer
Question on Extended Service Plan Exclusions
DW and I are getting ready to purchase a new motorhome.  Dealer talked to us about adding an extended service plan.  I realize there are those on both sides as to whether or not they are worth the dollars.  Personally, for most appliances I buy, I skip the service plan.  The quote for this one was $3,500 for 7 year, so seemed reasonable amount.  But my question, which the dealer was not able to answer, is:  would modifications (i.e. adding an extra batteries and an inverter, adding sway bars and Safe-T-Plus steering assist) void the service plan?
I know the devil is in the details. I did receive a copy of the service plan contract and found the following paragraphs which discuss modifications (and what the service plan does not cover).
a) Vehicles that have been modified beyond manufacturer's specifications that affect the breakdown, including, but not limited to: engine enhancements, suspension/lifts, tires/wheels, or that may increase the likelihood of a breakdown.
b) Aftermarket accessories or non-original equipment, components and systems not installed by the vehicle manufacturer, including, without limitation, anti-theft systems, radio/speaker equipment, telephones, cruise control, and sunroof.
c) In addition, this contract provides no benefits or coverage and the administrator has no obligation under this contract if your vehicle is modified from the vehicle manufacturers original specifications.
Paragraph b) above is rather obvious. If I add something, it isn't covered, but it does not appear to void the rest of the contract. Paragraph a) is less obvious and paragraph c) makes it sound as though if I do anything I could void the contract.
So, bottom line question, for those of you with experience in these matters: Before I plunk down a tidy sum of dollars, based on your experience and what you read above, if I add the mods I am thinking about, am I likely to void the service contract and end up wasting all my money?
Thanks
Don
Thanks
Don
