riven1950's avatar
riven1950
Question on Michelin LTX tires
I have set of Michelin LTX M/S LT tires ordered for my 2013 f150 cc.
I have been reviewing some previous post and I keep seeing some folks mentioning a 70,000 mile or 60,000 mile warranty on these tires.
From what I can find the LTX M/S LT tires have a 50,000 warranty. This is the tire with 3415 lb capacity and 80 psi. The Michelin site says 70,000 miles warranty @ speed rating T and H, 50,000 miles @ speed rating R. Best I can tell R rating is for LT use. What am I missing or am I just over thinking this. Is this the same tire just rated differently depending on use? No tire expert here.
I don't want or need an all terrain tire so it looks like the Defender LTX M/S LT is what I want, at least I think so.
  • I have been using them for the past 20 years on 4 different vehicles.
    You get what you pay for.
    I have easily gotten 70,000 and up to 80,000 out of them.
    The ride is far superior to other tires I have tried. We replaced the Firestones on the Suburban with these and the right was very much improved, much quieter and a lot smoother. I was going to go with Goodyear or a less expensive tire as now our tires age out rather than wear out, however the Michelins were only about 25.00 more each so it was a no-brainer to go with a far superior tire.
    I am replacing the 285-75-16's on the F250 after the first of the year with the LTX/AT LT and have an out the door price of 875.00 from a mom/pop tire shop a short drive away from here. I am currently running LTX/MS but am changing now since moving here I use a lot of boat ramps that are on dirt roads and need the traction.
    I will probably now have the same experience as eichacsj above and these will age out and crack as we now drive around 5000 miles per year and will not wear them out. I drive company car for work and our vehicles are only for personal pleasure use.
  • I run these (LTX), I had to replace them two years ago, not due to wear but because they had cracks in the tread valleys. They had been on for several years I want to think over a decade, ~ 60,000 miles. Only about half way through the tread, not sure of the depth but far from the wear bars.
Looking for advice before your next adventure? Look no further.25,163 PostsLatest Activity: Sep 07, 2025
