SoundGuy
Jun 13, 2016Explorer
turbojimmy wrote:
So Plan B is to run the Sewer Solution hose into the sewer line in the basement. Trouble is my basement window is about 4 feet off the ground. The crude yellow line shows where I need to go. Once inside, it drops back down about 4-5 feet to the sewer line.
And are you planning or able to actually connect to the house sewer line? You sure wouldn't want to be running black water waste into the house without an airtight connection. :E
I park my trailer here at the house during the season and always service tanks at home so I never have to line up at campground dump stations. To do so I installed a T in the main house sewer stack that happens to be located in the laundry room and ran it out through the wall to the outside where I installed a vertical stack into which I can stick the output hose from my Flojet Waste Macerator Pump. Been using this system for years now - quick, effiecient, and no smell whatsoever ... a series of 7 pics illustrating this setup starts here.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: May 12, 2019
