sptddog's avatar
sptddog
Questions about washer/dryer combo
We acquired our Pinnacle washer/dryer combo when we got our Fuzion in January. Tried to use it once, but can't quite figure out how to dry only - doesn't seem to have a setting for that. And I can't find the exact model online either (apparently pinnacle is now splendide?). Either way, some questions you all may or may not be able to assist with....
Do I leave the water turned on during drying? I assume I do, since it was designed to wash and then directly dry, but sometimes I'd just like to dry a beach towel or two or some swim suits....and I don't want to wash them first (there is no dry only setting....)
How do I know if I have a vented or not vented system?
Where does the washer drain water to? Gray tank I presume?
When I tried it last time, it never seemed to dry - how long on average will a few swim suits take? From reading, and hour and a half is normal?
Any other helpful tidbits? Thanks in advance?
  • Thanks! Does your selector knob actually say 'dry' on the wash cycle knobs? I have the dry knob turned to 30 minutes, but the wash cycles don't have a 'dry'.... (maybe I'm just dumb lol!). I feel so silly not being able to figure this out!
  • To dry only, make sure you have the dry time set to something over 0 minutes. Spin the selector knob to any of the dry settings in any of the cycles. A few bathing suits should take about 30 minutes (which is the shortest time I can set mine to). Towels will take longer. Press the start button. It should start drying. It may make a sound like rushing water but that will stop right away. Hope this helps
  • Try contacting the tech support below.
    Phone : 800-490-8018
    Fax : 832-201-0854
    Email : allen@pinnaclecombos.com
    The website says it has a dry only function. If the unit is vented look outside for a vent in the area where the unit is located in side.
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
