Grit_dog
Dec 31, 2017Navigator III
SweetLou wrote:
Just get some Tibrens. They only go into use when truck has weight on it. Research it and you will see that they are better and less expensive. It won't change the ride when empty either
While I like Timbrens and have used them in the past, as they are one of the most economical "solutions", their downside is they are extremely stiff once engaged. Kind of a not for all situations solution like airbags are.
To the OP, I cannot imagine the need for airbags on your truck and setup unless there is a specific need, like you're hauling another 2-3000lbs in the bed with the camper in tow.
You haven't replied as to why you think you need them as you're already running this truck and trailer together. What are you trying to accomplish?
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
