msmith1_wa
May 01, 2021Explorer
Your grill will work fine with two low pressure regulators in the line. The pressure at the burner will be which ever regulator has the lowest pressure setting.
Depending on the fire pit it may not work as well as if it was connected to a tank using the regulator supplied by the manufacturer. Sum fire pits use a 5psi regulator, much higher pressure than than the regulator for the rv system.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
