Community Alumni
May 03, 2021Not applicable
Lantley wrote:msmith1.wa wrote:stickdog wrote:Mel Stuplich wrote:
Most standard gas grills must be connected BEFORE the LP pressure regulator on the RV.
You can't double regulate.
Remove the regulator from your grill and then connect to your standard regulated quick connect.
Yes you can my dad did it a motorhome he had for many years.
A general rule of thumb is you can't double regulate.
I don't dispute that your dad was able to do it but for the most part to regulators will reduce the gas flow to inoperable levels.
Mine work fine double regulating. My weber is connected to the low pressure side of the propane regulator using a quick connect, the Weber has a regulator too. All works well.
JimR
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
