BillyW wrote:
No, max tow does not get you 7 lugs on any year. 7 lugs are a feature of the max payload package that was later renamed HD. The max tow option is included in the max payload/hd configuration by default though.
As far as I know, Ram's only fake half ton was the discontinued 1500 Megacab which was really a 2500 Megacab with softer springs. Same 8 lug axles and all.
Partially true.
The Max Tow option gets you a GVWR of 7650 or 7700lbs (pre 2015)
The HD option gets you (pre 2015) 8200lbs.
The Max Tow rims are standard 6 lug.
HD rims are 7 lug.
You need the Max Tow before you get the HD payload option.
Both require a 3.73 rear gear.
HD has a 4800 RAWR.
Max Tow has 4050lbs+/-.
Max Tow is not the HD. They're two separate options.
Also the HD option is only available on the 157" WB.
That's the Super Crew + 6.5" box or the Super Cab 8' box.
All this changes with the new aluminum bodied F150 where enough weight is shaved form it that it can offer the HD payload package without 7 lug rims.
I really wasn't trying to stir up this much controversy. I was just posting this because as most know the HD version (8200lb GVW) is an order only truck. So to see one for sale is kinda rare. I suppose as more time passes then more may pop up as the accumulated amount increases as time goes by.
BTDT with a 2010 F150. 7650lb GVWR. 1857lb payload. No tow mirrors.
