Frozen001
Jul 26, 2021Explorer
Hi, John… thanks for all the information. What you described is what I feel, I have 1200lbs trunion bars, and I have Had them marked driver/passenger since back in 2010 when I purchased these. I started without the DC then moved to the DC same year. I have 5 links under tension to return the truck front end to its unloaded height. This is with I want to say three or 4 teeth in head tilt. I spent a while getting this setup as always, between changing head tilt and number of links under tension. These bars are on their third TT. After this trip I am considering moving to an equalizer set up simple to gain some ground clearance. At another point leaving a parking lot, this time with a gutter and a large road crown the bottom of the cams hit. I could decrease the head tilt to gain some clearance but I likely would have to und up with only 4 links under tension and I fear I might get a binding situation in tight turns. One thought I also have is I wonder what my true tongue weight is when loaded. Another thing to check when I return home. This is our first long distance trip with this TT, as COVID limited our travel last year. It tows nice and straight, very easy towing actually.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Mar 30, 2026
