rhetthughes
Jul 24, 2018Explorer
BurbMan wrote:
There is supposed to be a trim piece ob the bottom of the door that holds the panel in place. I would call Dometic and see if you can fix the problem right before you glue it in there permanently....because you know that once you do that you'll need to take that panel out....
It does have the trim piece. And it appears to be intact - all the little tab pieces are there and not broken off. It just won’t hold that panel. But that’s a good idea. I’ll call them and see if they have heard of this and if a new trim piece on the bottom would fix it.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 05, 2026
