afidel
Dec 06, 2022Explorer II
RVER wrote:
well made rigs actually have triple pane glass all around, remember your vents loose a lot of heat so put vent pillows in the vent, if on electric a ceramic heater helps a lot. There are ways of making heat with ceramic pots but would not entertain that thought due to fire hazards. Put bubble wrap on windows or better is the foil bubble wrap. Make sure all seals are good to keep heat in and cold out. Some rigs have insulated basements and covered bottoms so air infiltration is low.
One thing I've noticed is that the snow melts fastest where the AC vents are. I've been meaning to buy some insulated vent plugs, I've already got pillows for the 14x14 air vents an Reflectix for the windows which helps a ton.
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 11, 2025
