LJAZ
Apr 12, 2022Explorer
When the Jensen unit in my trailer would no longer play DVD's I spent a ton of time researching to find a quality brand to replace it. Only to find, as you have, that the brands available for RV's are all pretty much junk. If I wanted quality I was going to have to get separate components and do a bunch of modification to fit and wire them up. In the end I decided to just get a newer model Jensen from Crutchfield. It was cheap enough that I could just live with it until it broke and throw it away for new one. On the plus side it was the same dimensions as the old one and the wiring harness connectors were identical so It was literally plug and play. 5 minutes start to finish.
Looking for advice before your next adventure? Look no further.25,201 PostsLatest Activity: Aug 08, 2017
